Unitrack 1100 B's and P's
#1 PostAuthor: Al » Thu Dec 01, 2011 12:45 pm
Only got the J and B manual so looking for data for the Unitrack barrels and pistons please.
Bore is 72.5mm standard for B's and Unitrack Correct?
Pistons diameter for J's i have in the manual but this is irrelevant here.
Anyone got piston diameter and service limit for piston to cylinder clearance for the Unitrack please.
Similarly; Ring end gaps i have data for the J's but not the unitrack.
Anyone got first and second ring end gap data plus service limit for the Unitrack please?
martinz1000r
#2 PostAuthor: martinz1000r » Thu Dec 01, 2011 4:48 pm
Al, you are welcome to borrow the unitrak service manual supplement if you want? I'll need it back but not before Christmas.
martinz1000r
#3 PostAuthor: martinz1000r » Thu Dec 01, 2011 4:52 pm
standard bore is 72.5 - 72.512. Service limit is 72.6. For ring gaps it refers you back to base manual section 3-17
#4 PostAuthor: Al » Thu Dec 01, 2011 10:08 pm
Many thanks Martin i have the base manual so with that and the info you supplied above i think we are there.
Thanks for the kind offer and i'll bear it in mind if other things crop up.
