z1100r carbs
flybo
z1100r carbs
#1 PostAuthor: flybo » Sun Dec 04, 2011 11:36 am
hi. can any body tell me if a set of gsxr750 29mm flatesides carbs. are better than the standerd carbs on my 1100r??and would they fit.. :D and make it run better...
#2 PostAuthor: Al » Sun Dec 04, 2011 1:11 pm
hi. can any body tell me if a set of gsxr750 29mm flatesides carbs. are better than the standerd carbs on my 1100r??and would they fit.. Very Happy and make it run better...
Couldn't say for sure but 29mm is a little small in my opinion.
You will get very high gas speed through the venturi and may need to down jet them, making the overall set-up un-rideable.
34mm or 36mm seems to be about optimium from approx 1100 to 1300cc with a road setup all things being equal.
What air filters do you have and i guess we are talking about 34mm CV's?
Is it standard setup for the top end; cams, porting, valve size and valve timing etc etc etc?
Which exhaust is it?
Which ignition set up do you have? 'S' or 2000 or another?
Roughly; CV's work best with standard airbox give or take. You can get a K&N for the standard airbox. Radical or incorrect valve timing can supress inlet vacuum giving problems with flow characteristics, it can help to set the two inner carbs a little richer, you can 'pre-load' the springs above the slides to stop them opening too quickly (not recommended) slower opening of the throttle often results in increased power delivery, a weaker mixture can give better power delivery also (right up to the point of detonation) but care is needed here, air leaks around the inlet stubs are a common failing, and so it goes on.
What are the specific symptoms of poor performance you are experiencing?
