Could anyone advise the correct method for crimping Taylor Leads at the coil end?
A photo of the correct end result would be great!
Taylor Leads - Coil End
For Dyna coils: Just look at a car lead, you need to do the same sort of thing, I made a crimper by drilling through two bits of steel flat bar, bit of hacksaw work and filing. Then put them in the vice and squeeze up.
I'll send you a photo of it over the weekend.
Original Kawa coil leads are molded in and you won't fit Taylor leads to them easily.
Rich wrote:For Dyna coils: Just look at a car lead, you need to do the same sort of thing, I made a crimper by drilling through two bits of steel flat bar, bit of hacksaw work and filing. Then put them in the vice and squeeze up.
Thanks & yes it's for fitting to Dyna Coils
