Dyna S - Gpz question
sockpuppet
#1 PostAuthor: sockpuppet » Wed Dec 07, 2011 6:50 pm
Hi everyone
Am i correct in thinking that if i fit a Dyna S ignition to my Gpz1100 i can get rid of the IC Igniter and so a whole lot of extra wiring ?
I am about to start trying to sort out the heavily bodged harness on my bike
See Pic
http://s780.photobucket.com/albums/yy84 ... =ALAMO.jpg
( There`s more Bullets than the Alamo under that seat !!)
Also is it worth the hassle of importing one from the states or should i just get one from Dave at Z power ? (with my members discount !)
Any advice gratefuly recieved
Cheers Mick
#2 PostAuthor: Pigford » Wed Dec 07, 2011 7:03 pm
Yes
debben1
#3 PostAuthor: debben1 » Thu Dec 08, 2011 1:46 pm
Depends which GPz, The early type of housing with 3 screw holes for the ignition mounting plate and a mechanical auto advance are straightforward, the later type where the back plate was eliminated and the pick ups mounted directly to the housing wont be staright forward, you also need to source an auto advance unit for the later type as they never had one. Regards, Steve
sockpuppet
#4 PostAuthor: sockpuppet » Thu Dec 08, 2011 1:57 pm
Thanks Mr Pigford
Kylie answer - Short and sweet !!
Its an early one so should be straight forward (thanks Steve)
Cheers Mick :D
