Electronic Tacho?
angeleddie
Electronic Tacho?
#1 PostAuthor: angeleddie » Fri Dec 09, 2011 12:44 pm
Thinking of buying an electronic tacho (£70), to fit my Z1000a1, has anyone out there had any experience of these ? i.e. fitting, pitfalls etc
cheers
Angeleddie
Garn 1
#2 PostAuthor: Garn 1 » Fri Dec 09, 2011 4:41 pm
AngelEddie.... I've never fitted one on a motorcycle. I would think the only issue would be blanking off your tacho take-off point and removing redundant worm gear.
RegardZ.
#3 PostAuthor: Rich » Fri Dec 09, 2011 7:09 pm
I have a Stack, does exactly what it says on the box. Easy to fit and accurate plus it has the added benefit of having "this unit is not affected by vibration" printed on the instructions.
Get a blanking off plug for the mechanical tacho drive and away you go
:D
