Hi
I need some more advice please.
I have a dry blackening of plugs and the bike runs poorly and is incapable of travel more than very short distances.
My first target was plugs and the plug caps. All replaced. The carbs were the next item. An incompetent aquaintence damaged carb 1 beyond repair trying to get the jet needle out the wrong way and ripped a bit of casting!
I managed to obtain replacment carbs and today fitted them with the correct main jet 115 size for the Harris street legal pipe I have. I did no other work on the new carbs. No change stil blacks up on all cylinders.
The other carbs had main jet of 120 in them and I also now have size 117 to use. Tomorrrow I am checking the compression and thevacuum balance of the carbs. If this does not solve it I am at a loss.
Suggestions please
Phil
Z900 Running rich?
Hi Phil...
Have a look at this if nothing else works it may be of use.
http://www.wgcarbs.com/index.php?option ... &Itemid=26
this guy also recomendsthis on his site...
We jet our carbs for pods and aftermarket pipes. We use #120 main jets, #17.5 pilot jets and the jet needles 5DL31-3.
- big green bus
