Stator housing oil leak
Tonka
#1 PostAuthor: Tonka » Mon Dec 26, 2011 6:04 pm
I have an oil leak coming from the stator housing on my Z1a where the wires come out and wondered what the most effective solution or sealant Is to stop it - fed up of getting my boot covered in oil :shock:
Any advice appreciated
Z1RII
#2 PostAuthor: Z1RII » Mon Dec 26, 2011 6:40 pm
did you change the seal of the housing? if so, you replaced it wrong side up.
PAULJAC47
#3 PostAuthor: PAULJAC47 » Mon Dec 26, 2011 7:12 pm
Neil Best fix is a new seal but i have had some success with cleaning with brake cleaner and RTV silicone,Cheers Paul J
Tonka
#4 PostAuthor: Tonka » Mon Dec 26, 2011 7:13 pm
Not done anything to it as yet. I was told just fitting a new seal without using some sort of sealant will not stop it leaking. Only want to fix it once :D
#5 PostAuthor: Pigford » Mon Dec 26, 2011 9:11 pm
Very common, they all do it :wink:
#6 PostAuthor: chrisNI » Mon Dec 26, 2011 9:13 pm
Bloody hard to seal up even with a new seal. :(
baz
#7 PostAuthor: baz » Tue Dec 27, 2011 9:38 am
take the seal out, clean the wires and the casing with brake cleaner then fill it with black sikaflex, job done :D
#8 PostAuthor: Ginger Bear » Tue Dec 27, 2011 7:50 pm
Possibly worth 'roughing up' both rubber & casing to provide a good 'key'.
I have used Threebond 1211 in the past, with exceptional results. The important thing is to remove all oil/grease from the surfaces to be sealed, and as already said, brake cleaner is a good way to do this.
Threebond 1211, ain't the cheapest. But your Zed deserves the best. Do it properly & you'll only do it once.
http://www.ebay.co.uk/itm/Threebond-121 ... 563722ce95
#9 PostAuthor: Ginger Bear » Tue Dec 27, 2011 7:56 pm
z1000puddin
#10 PostAuthor: z1000puddin » Tue Dec 27, 2011 8:15 pm
One thing is to make sure that it aint leaking from the actual wires that pass through the rubber .
I fitted a new rubber & it leaked even with kawabond.
Found out after that the wires had been replaced previously with a slightly smaller gauge and therefore not making a tight seal.
Stu
Zed til Dead
ROZZER
#11 PostAuthor: ROZZER » Thu Dec 29, 2011 12:29 pm
As others have said, the real key to getting an effective seal is to make sure that the area, rubber seal and wires are completely degreased. I personally have used cellulose thinners to degrease, then used black silicone sealant- ensure that when applying sealant you get it all around the wires. I usually cut back the braided outer of the wires to expose the plastic insulation , this gives better results too.
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
