z1000a2 hydraulic clutch conversion
#1 PostAuthor: ADRIAN H » Thu Dec 29, 2011 7:24 pm
What is the best master cylinder to use with this ? Just won on german ebay.
#2 PostAuthor: Ginger Bear » Thu Dec 29, 2011 7:28 pm
ZX7R if you want a remote resevoir or ZZR1100/1200, ZRX1100/1200 if you want something with an integral resevoir.
#3 PostAuthor: Pigford » Thu Dec 29, 2011 7:39 pm
Phwarrrrr :twisted: After summink like that for me Harris :!:
Any chance of a cardboard template - halp me get one made - or even make one meself :shock: Make sure you keep us updated with how you get on with it :wink:
#4 PostAuthor: ADRIAN H » Thu Dec 29, 2011 8:12 pm
Pigford wrote:Phwarrrrr :twisted: After summink like that for me Harris :!:
Will happily make you a template, once I am in receipt. May take me a bit longer to set up as bike is up a debben performance - having a full engine rebuild. Casings have been stripped and polished, hopefully will get it back before end of january.
Bike as it was 4 weeks ago.
#5 PostAuthor: ADRIAN H » Thu Dec 29, 2011 8:14 pm
Ginger Bear wrote:ZX7R if you want a remote resevoir or ZZR1100/1200, ZRX1100/1200 if you want something with an integral resevoir.
Many thanks, very helpful. Ta Adrian.
#6 PostAuthor: Ginger Bear » Thu Dec 29, 2011 8:17 pm
No problem Adrian.
Whats the spec on that motor? I see it has a 'J' or Uni-Trak top end. :up
#7 PostAuthor: ADRIAN H » Thu Dec 29, 2011 8:35 pm
Ginger Bear wrote:No problem Adrian.
Has a APE cam chain idler adapter to allow Z1000J cylinder head to be fitted to earlier bottom end. Head is a Z1000J head with a pair of Kent cams. Block is bored out to 1075 with a Wiseco 1075 big bore kit.
Engine has had a full strip down, new welded crank and bearings being fitted as we speak.
z1000puddin
#8 PostAuthor: z1000puddin » Thu Dec 29, 2011 9:50 pm
Im using a GPZ900R slave cylinder & lever/reservoir set up.
Using a modified z1000a2 casing with recess welded/machined in to take the bolt able
slave cylinder
Zed til Dead
#9 PostAuthor: Rich » Fri Dec 30, 2011 8:30 am
Do a P&M style lifter, less weight, better action and feel.
