Morning all,
I am looking to buy the pipe/fuel line that comes off the left hand side of the fuel pump and goes to the fuel filter. When I bought my B1 the last owner had out an inline fuel filter on it but I now have a new original filter so need this pipe. It is unique in that it starts out with a larger diameter outlet from the fuel pump then reduces in internal size to fit onto the fuel filter.
Last bit I need before completeing the fuel injection part of my rebuild.
All you guys that have converted to carbs have you still got the old pipe on the pump.
FUEL PUMP PIPE B1 B2 WANTED P/NO 92059-1165
Ian,
I appear to have all/most of the bits for B1 injection system....never going to use so you can have what you want. On parts diag this pipe is shown as quite short but on bike is longer as pump below/in front of battery box and filter under LH side panel. Does that sound right to you?
Matt
Matt
Matt C
