front brake disc
Redbeard
front brake disc
#1 PostAuthor: Redbeard » Thu Jan 05, 2012 8:33 pm
I'm after a single front disc from any of the following bikes please;
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D3 (Z1R) (1980)
KZ1000-G1 (Classic) (1980)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-G1 (LTD II) (1980)
1979 Z1000ST
LTD Project
#2 PostAuthor: LTD Project » Thu Jan 05, 2012 9:19 pm
Might be able to help you but cannot say for sure until the weekend when I will have time to get to the parts and check that I am not misleading you. Obviously if someone comes up with something in the meantime, fill your boots!
Redbeard
#3 PostAuthor: Redbeard » Thu Jan 05, 2012 9:21 pm
No problem mate, appreciate it.
1979 Z1000ST
hillbilly
#4 PostAuthor: hillbilly » Fri Jan 06, 2012 7:27 pm
four hole mount,six hole mount,drilled,not drilled.i have a drilled six hole mount.
Redbeard
#5 PostAuthor: Redbeard » Fri Jan 06, 2012 8:54 pm
hillbilly wrote:four hole mount,six hole mount,drilled,not drilled.i have a drilled six hole mount.
4 hole mount, drilled or not doesn't matter, cheers.
1979 Z1000ST
malc87
#6 PostAuthor: malc87 » Sat Jan 07, 2012 12:01 am
#7 PostAuthor: paul doran » Sat Jan 07, 2012 2:29 pm
Malc thats DK
that disc will very probably be well knackered
PJ
#8 PostAuthor: PJ » Sat Jan 07, 2012 6:34 pm
Z1parR
#9 PostAuthor: Z1parR » Sat Jan 07, 2012 8:07 pm
PJ wrote:http://www.ebay.co.uk/itm/KAWASAKI-Z650-Z900-Z1000-DRILLED-DISCS-/280787711903?pt=UK_Motorcycle_Parts&hash=item416040779f#ht_1578wt_922
Same guy has quite a few other items for sale too .
0172 . Geoff Parr
Redbeard
#10 PostAuthor: Redbeard » Sat Jan 07, 2012 8:49 pm
thanks for the links guys, unfortunately i missed that set pj. i will keep looking. basically i am upgrading the knackered caliper on an early z750 for a gpz unitrak one and it requires a narrower disc. the twin disc zeds are narrower than single disc i have.
1979 Z1000ST
000zeds
#11 PostAuthor: 000zeds » Sat Jan 07, 2012 10:22 pm
Redbeard,I have 2 discs from a Z65B1 and they have been skimmed down to 4.5mm,Are these any good ?
Zeds-R-Us
Redbeard
#12 PostAuthor: Redbeard » Sat Jan 07, 2012 10:53 pm
twozeds wrote:Redbeard,I have 2 discs from a Z65B1 and they have been skimmed down to 4.5mm,Are these any good ?
if they're 4 bolt then they're exactly what i need. i actually only need 1 but if you'd prefer to shift the pair that's fine.
1979 Z1000ST
000zeds
#13 PostAuthor: 000zeds » Sun Jan 08, 2012 4:12 pm
Redbeard , they are 4 bolt , how does £25 + postage for the pair sound ?
PM your details.
Zeds-R-Us
LTD Project
#14 PostAuthor: LTD Project » Mon Jan 16, 2012 8:42 pm
Red
Took slightly longer than I thought, but if you still need it I did find the spare KZ1000 front disc, tucked away under a shed load and a half...
four holes, drilled
Let me know
