GPZ1100 B2
GPZ1100 B2
#1 PostAuthor: paul doran » Thu Jan 12, 2012 6:15 pm
can anyone supply Me with the size of the spacers fitted the GPZ11 B2 front wheel please
a diagram would be helpful too
#2 PostAuthor: z1bman » Thu Jan 12, 2012 6:41 pm
Price Qty
41060 41059-026 GEAR,SPEEDOMETER $19.98
41060A 41060-1016 PINION,SPEEDOMETER,9T $10.38
41064 41064-1006 RECEIVER,SPEEDOMETER $7.62
41064A 41064-1008 RECEIVER-SPEEDOMETER $10.87
41068 41068-1031 AXLE,FRONT $44.00
41073 41073-1156-21 WHEEL-ASSY $574.80
41073A 41073-1139-18 WHEEL-ASSY,FR,BLACK $564.98
41078 41078-1024 CASE-ASSY-METER GEAR, $58.70
92022 41063-001 WASHER THRST SPD PINI $2.97
92022A 41063-001 WASHER THRST SPD PINI $2.97
92027 41069-031 COLLAR,FRONT AXLE $14.05
92027A 92027-1505 COLLAR,15.2X22X55 $7.00
92027B 92027-1225 COLLAR,FR AXLE L=30MM $9.01
92033 92033-1041 CIRCLIP,42MM $3.33
92043 41082-001 PIN,SPRING $2.97
92049 92049-1057 OIL SEAL,BJN30427-C3 $4.88
92049A 92049-1058 OIL SEAL,AG1144AO $4.88
92087 92087-1002 BUSHING,METER GEAR $11.23
601 601B6302Z BEARING BALL #6302Z $12.21
#3 PostAuthor: paul doran » Thu Jan 12, 2012 7:58 pm
cheers for that
#4 PostAuthor: Al » Thu Jan 12, 2012 10:43 pm
Do you need measurements to make youre own with?
If so i can measure the J1 ones and do a sketch if it helps. They look to be the same ish. Is it just the outer one or the bearing spacer as well.
As you know the J1 speedo arrangement is different.
#5 PostAuthor: paul doran » Thu Jan 12, 2012 10:56 pm
Al I think I have all these spacers
i need to check them out
I dont however have the speedo drive
I wonder is it common to any other model ?
#6 PostAuthor: Al » Thu Jan 12, 2012 11:02 pm
That'll learn me, should have read before typing, the sizes are on there. :oops:
Dont know about commonality i only have that useless hall affect one on mine.
#7 PostAuthor: z1bman » Sun Jan 15, 2012 10:52 am
application list for gpz1100 speedo drive
EN450-A1 454 LTD (1985)
EN450-A2 454 LTD (1986)
EN450-A3 454 LTD (1987)
EN450-A4 454 LTD (1988)
EN450-A5 454 LTD (1989)
EN450-A6 454 LTD (1990)
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-J3 (1983)
KZ1000-R1 Eddie Lawson Replica (1982)
KZ1000-R2 Eddie Lawson Replica (1983)
KZ1100-B1 GPz (1981)
KZ1100-B2 GPz (1982)
KZ550-H1 GPz (1982)
KZ550-H2 GPz (1983)
KZ700-A1 (1984)
KZ750-L3 (1983)
KZ750-R1 GPz (1982)
VN700-A1 LTD (1985)
VN750-A10 Vulcan 750 (1994)
VN750-A11 Vulcan 750 (1995)
VN750-A12 Vulcan 750 (1996)
VN750-A13 Vulcan 750 (1997)
VN750-A14 Vulcan 750 (1998)
VN750-A15 Vulcan 750 (1999)
VN750-A16 Vulcan 750 (2000)
VN750-A17 Vulcan 750 (2001)
VN750-A18 Vulcan 750 (2002)
VN750-A19 Vulcan 750 (2003)
VN750-A2 Vulcan 750 (1986)
VN750-A20 Vulcan 750 (2004)
VN750-A21 Vulcan 750 (2005)
VN750-A3 Vulcan 750 (1987)
VN750-A4 Vulcan 750 (1988)
VN750-A5 Vulcan 750 (1989)
VN750-A6 Vulcan 750 (1990)
VN750-A7 Vulcan 750 (1991)
VN750-A8 Vulcan 750 (1992)
VN750-A9 Vulcan 750 (1993)
VN750A6F Vulcan 750 (2006)
ZX1100-A1 GPz (1983)
ZX1100-A2 GPz (1984)
ZX750-A1 GPz 750 (1983)
ZX750-A2 GPz 750 (1984)
ZX750-A3 GPz 750 (1985)
ZX750-E1 GPz 750 Turbo (1984)
ZX750-E2 GPz 750 Turbo (1985)
