HELP ! Wont start. Im bloody jinxed.
andyb1962
#1 PostAuthor: andyb1962 » Sun Jan 15, 2012 12:36 pm
This morning kicked her up and it went solid in the kick start.
I kicked through it with more force and it cleared.
Now it wont start. Electric start spins over fine bit no ignition.
The plugs spark and the valves move (ive looked) so i dont think its the cam chain. it runs dyno S ignition which looks Ok but i dont know the settings.
Could the cam chain have "moved" ?
I dont want to destroy my engine so im very wary!
apprecitions in advance.
:cry: :cry: :cry:
Andy :wink:
#2 PostAuthor: z1bman » Sun Jan 15, 2012 1:19 pm
1st thing to do is compression test
#3 PostAuthor: Pigford » Sun Jan 15, 2012 2:01 pm
Assuming it kicks over OK as normal......
Whip the plugs out - then spin her over on "electric boot" and put your thumb over plug hole as you turn engine over to feel for compression, keep plugs in HT leads and earth them on cylinder head & you can watch for sparks too :wink:
Cam chain can jump a tooth and not wreck the engine.
hillbilly
#4 PostAuthor: hillbilly » Sun Jan 15, 2012 2:09 pm
if the cam chain has jumped a tooth,before spinning the engine with electric start button,mybe a good idea to line the timing marks up first and check it ,then check weather or not the cam chain tentioner is slack,if it has jumped once,it could do it again and do serius damage.
PAULJAC47
#5 PostAuthor: PAULJAC47 » Sun Jan 15, 2012 3:50 pm
Not fuel locked by any chance???
andyb1962
#6 PostAuthor: andyb1962 » Sun Jan 15, 2012 4:00 pm
deffinatly not fuel
i have four sparks and compression appears normal.
hope fully no serious damage done as bike has not fired yet.
cam chain tensioner WAS slack. i have nipped it up on the lock nut.
i need an idiots guide to checking timing marks please
Andy :wink:
#7 PostAuthor: kev edwards » Sun Jan 15, 2012 4:26 pm
Hi Andy, the last compression test i done on the bike was at 36,000 miles and i got 150psi across all four, if the last owner gave you the haynes manual i gave to him the timing will be in that, but here is the picture from the clymer manual, the ignition timing should not have moved as the dyna is the one i put on and was static timed to start with and also done with a strobe.
Steve Cooke
#8 PostAuthor: Steve Cooke » Sun Jan 15, 2012 6:54 pm
It sounds like you may have bent a valve (I hope not) but if your camchain adjuster was slack as you say and you kicked through a lock up it's a distinct possibility, a compression test may confirm this but it's not always obvious it depends on the extent of damage if any.
Fingers crossed!
PS. The valves can still move even when bent, it might pay to measure the shim clearances to see if there is any that are on the large side which would indicate a bent valve.
andyb1962
#9 PostAuthor: andyb1962 » Wed Jan 18, 2012 7:17 pm
Done a compression test and no3 is way down compared to the rest.
DAMN! So weekend will cause for serious investigations.
:evil: :evil: :evil:
At least its winter so time is on my side before 'the summer' arrives
Andy :wink:
#10 PostAuthor: Pigford » Wed Jan 18, 2012 7:37 pm
Could be a sticky valve (sticking in guide) or bent valve or a tight shim - lack of clearance ?
Maybe rings sticking - can free after a few miles running.
Leaky head gasket - cracked cylinder head (not unknown near plug thread.
Compression testing should be done on a HOT engine :!:
andyb1962
#11 PostAuthor: andyb1962 » Wed Jan 18, 2012 7:51 pm
Pigford wrote:Could be a sticky valve (sticking in guide) or bent valve or a tight shim - lack of clearance ?
I realise it should be done on a hot engine but it wont fire :lol:
So i thought i could do one for comparison purposes.
I will know more by weekend. Thanks anyway its appreciated
Andy :wink:
Garn 1
#12 PostAuthor: Garn 1 » Thu Jan 19, 2012 8:02 am
That locking of kick- start, could be a shim that has never seated and was waiting for a bit more clearance to pop half way out and jam. When you forced harder it either popped back, broke in half or is laying in there!
Worth while having an inspection under the rocker cover.... Not easy to see!
RegardZ
#13 PostAuthor: Pigford » Thu Jan 19, 2012 8:22 am
Garn 1 wrote:That locking of kick- start, could be a shim that has never seated and was waiting for a bit more clearance to pop half way out and jam. When you forced harder it either popped back, broke in half or is laying in there!
RegardZ
Good point Garn1 - Although I'm sure Andy did do it - its always good to double check clearances once shims have been swapped, and shim seating - before putting the cam cover back on :wink:
#14 PostAuthor: kev edwards » Thu Jan 19, 2012 8:42 am
I last measured the shims in jan 2011 and always aim at halfway between the min and max measurements, unless the next owner has changed shims the gaps should be ok, if the tensioner came loose you may have bent a valve, the head was last off about six years ago when i had the valve seats and valves recut at Dartford rebore and put the studs in for the cam caps at that time, they are the first set i made, i found the second set a couple of months ago, i hope it's not to serious.
garyd
#15 PostAuthor: garyd » Thu Jan 19, 2012 8:52 am
This may not be of much help, but I did have a Z1000A1 that jumped a tooth on the exhaust cam. It appeared to run fine but just seemed a little flat.
It was only when I decided to fully investigate, did I find out what had happed and the exhaust valves were just ever-so -slightly bent.
Unstressed engines eh?
