Mikuni VM28SS Carb - Choke pick-up tube - help required.
njwmct
#1 PostAuthor: njwmct » Sun Jan 15, 2012 12:42 pm
In need of a bit of help!
Got a Mikuni VM28SS carb (Z1000 MKII) where the brass pick-up tube for the choke fuel feed has sheared off.
As there is a small section of brass stub still showing in the carb body does anyone know if the brass pick-up tube is a push fit or screw in ?
Or has anyone had a similar problem & managed to come up with a solution or repair?
Or failing that has anyone got a good No.1 VM28SS carb body that they would want to sell?
#2 PostAuthor: z1bman » Sun Jan 15, 2012 1:15 pm
they are a push fit. i would try taping a small torx screw driver bit into what is left of the tube then heat around the tube with a heat gun. then twist it gently until it comes out.
Z1parR
#3 PostAuthor: Z1parR » Sun Jan 15, 2012 4:51 pm
Can anyone show a pic or diagram of the needed part as i'll have one in my scrap set of 28s .
0172 . Geoff Parr
njwmct
#4 PostAuthor: njwmct » Sun Jan 15, 2012 6:28 pm
Hi,
I don't have a picture but I can try to explain.
Remove the float bowl & the Brass pick-up tube is sticking out directly beneath the the choke plunger I'm told that it's a push fit into the carb body
anyone show a pic or diagram of the needed part as i'll have one in my scrap set of 28s .[/quote]
Z1parR
#5 PostAuthor: Z1parR » Sun Jan 15, 2012 6:41 pm
Right got you , 33mm long 3mm od brass tube that i've just taken out of my carbs , this one has your name on it :lol:
PM me your address and i'll post it tomorrow .
0172 . Geoff Parr
