Mikuni Carb VM28SS Choke Pick-up tube
njwmct
#1 PostAuthor: njwmct » Sun Jan 15, 2012 6:17 pm
Anybody got a brass pick-up tube for the choke circuit?
(The one that goes down into the float bowl & draws up fuel when you lift the choke plunger) - I've been advised that it's a push fit into the carb body
In my case it's for a Z1000 MKII carb (VM28SS) but I'm guessing it's a part common to many different Mikuni Z Carbs ?
If nobody has the pick-up tube then maybe a scrap or good carb body with one in?
njwmct
Re: Mikuni Carb VM28SS Choke Pick-up tube
#2 PostAuthor: njwmct » Sun Jan 15, 2012 7:11 pm
GOT ONE - BIG THANKS TO Z1PARR!
njwmct wrote:Anybody got a brass pick-up tube for the choke circuit?
