rear brake hub wear limit
hi all, was it just the z1 or did the early z1a have no wear limit indicator on the rear hub...
I have seen many Z1A's without the wear indicator. It was one of those change over Z1 to Z1A things , where they used up old stock! Although the cut off for Z1's was Z1F-20,000 many components of the Z1 went over into the Z1A. However, if restoring I would use the Z1A (wear indicator) hub.
RegardZ.
RegardZ.
