Z650 Carb Air Vent Tubing Supplier/ Part Needed Please
pertonpc
#1 PostAuthor: pertonpc » Tue Jan 31, 2012 7:46 pm
Hi Folks
Trying to find a supplier for carb air vent tubing - needs to be roughly...
5mm internal diameter
8mm outer diameter
250mm length
2 identical pieces needed (50cm total)
There is a kawa part no. for it - 2x 92059-1045 which became 92059-1128
or has anyone found a good supplier. I want stuff which is clear but with the pink tint to it as per factory fitted if possible. Has anyone found anything that is a close match to the factory fitted hose please??
Do Kawa dealers sell the correct hose off the roll??
Thanks a lot from Mark
