Does anyone know if there is any difference between the air filter elements on a Z900A4 and a Z1000A1?
Andy
Z900 Air Filter Element
Forgive me if I'm wrong.
Memory ain't what it used to be..........The two aren't interchangeable. Z1000 is around 10mm taller than the Z900 element. Now I think....the Z1000 has a fully recessed tab on top the Z900's is only partly recessed
Begging your pardon sir, but you did say that you'd like .................a green one?
