bolt hole on z1000 frame
hi all, i was mooching round the bike looking for things to do on it tomorrow.
while i was mid mooch, i started wonderin what the 6mm bolt hole is for, that is on the bracing plate, that is welded to the frame top tubes just above the airbox?
the same plate also has an oval hole in it, i had a look through my assembly and prep manual but didnt find anything, is it a throw back from an erlier model ???
thanks for any info, bye for now, bored of washington
or ........... what I thought I'd saidCAT3 wrote:RGH wrote:CAT3 wrote:Just a point of interest, on my Z900-A4 the 6mm hole has a threaded nut welded to the top of it, but it was never used for anything. I always wondered what it was for.
It is not a 6mm "taped hole" it is a 6mm welded nut on all models.
RGH, that's what I meant to say
CAT3 wrote:or ........... what I thought I'd saidCAT3 wrote:RGH wrote:CAT3 wrote:Just a point of interest, on my Z900-A4 the 6mm hole has a threaded nut welded to the top of it, but it was never used for anything. I always wondered what it was for.
Sorry CAT3, it was another posting that said it was a taped hole.
Users browsing this forum: Bing [Bot] and 46 guests
