Output shaft o-ring
Steve Cooke
Output shaft o-ring
#1 PostAuthor: Steve Cooke » Mon Jun 11, 2007 9:20 pm
Does anybody know the dimensions ie. thickness of the o-ring thats sits behind the distance collar behind the engine sprocket, the engine oil seal kit I got doesn't have this one in it.
Cheers Steve
#2 PostAuthor: chrisNI » Tue Jun 12, 2007 12:18 am
It's available okay I got one recently.
Steve Cooke
#3 PostAuthor: Steve Cooke » Wed Jun 13, 2007 9:28 pm
Hi chris, I thought it would be available it's just that I have a box of o-rings and it would allow me to carry on my engine rebuild without having to wait for delivery.
Steve
Garn 1
#4 PostAuthor: Garn 1 » Wed Jun 13, 2007 10:08 pm
Steve, the o-ring in question is a "skinny" one, approx 1.5 mm thick and an ID a little smaller than the shaft approx 24mm. Sometime it's hard to see if you have installed it or not, it's so thin!
RegardZ
Steve Cooke
#5 PostAuthor: Steve Cooke » Wed Jun 13, 2007 10:26 pm
Hello Garn 1, I thought as much thank you very much for that info thats exactly what I needed to know.
Thanks again
Steve
