Replacement twist grip
HowieD
#1 PostAuthor: HowieD » Sun Feb 12, 2012 11:40 am
Hello,
can anyone recommend a replacement throttle twist grip assembly for a Z1-R ?
I'm looking to change the Handle bar switchgear but as the standard one is built in it might be a problem.
Not really looking for a quick action one.
Ta in advance
H
#2 PostAuthor: z1bman » Sun Feb 12, 2012 1:30 pm
it is the same as a gpz550d1 twin shock model
#3 PostAuthor: Rich » Sun Feb 12, 2012 1:34 pm
If you want a start/ run/kill arrangement use a GS1000 throttle. They are getting hard to find though (read that as more than a tenner) takes the same cables as Z1000, you just have to file the nipples downa little. Will allow fitment of Nissin / AP master cylinders
http://www.ebay.co.uk/itm/suzuki-gs1000 ... 53e8513b65
HowieD
#4 PostAuthor: HowieD » Sun Feb 12, 2012 2:13 pm
Ah !
Thanks for your replies - I didn't make myself clear enough, I'm looking at a stand alone one without switch gear built in.
regards
Howie
