hi guys,
quick question, when replacing old 2 part head gasket with a new one piece head gasket would one refit the orings under it as well ?
bike is gpz1100 b1 ,
thanks mick
fitting comtec head gasket
what,s there to say except we,re all mad on here.
No fill o-ring groove with RTV and let it go off. Trim excess above block surface off then put a light smear onto each side of the gasket instead of the o-ring before fitting.
This way you don't have to get the excess out of the tunnel after fitting.
- paul doran
