carb cleaning
zman
carb cleaning
#1 PostAuthor: zman » Mon Feb 20, 2012 4:50 pm
Ive stripped my carbs,Any one got good way of cleaning them. :?:
especially the out side
keep thoses wheels turning
DaveZ1
#2 PostAuthor: DaveZ1 » Mon Feb 20, 2012 5:09 pm
Hello Keith, looked at this myself for my Z1A project and didnt fancy paying the £650 to have them done proffessionally so had a crack at it myself. I have access to a hot aquaeus cleaning bath and a bead blasting cabinet. But the rest is just bit of work and patients. some before and after photos on my DavesZ1A project on projects forum. I have had some more bits replated by Mikey since those pics were taken so they look even better now :D and they are now just about to go back on the bike. and will be posting more photos on the project soon.
pertonpc
#3 PostAuthor: pertonpc » Mon Feb 20, 2012 7:03 pm
Soak em in cellulose thiiners and then clean em with 00 gauge wire wool, fine scotchbrite pad and little brass dremel brushes for the fiddly bits.
Brought mine up good anyhow.
Don't get thinners on the non metal parts though!!
Cheers from Mark
Garn 1
#4 PostAuthor: Garn 1 » Wed Feb 22, 2012 10:19 am
A long time ago, someone recommended to dunk the carbs for a while in brake fluid. I have done it without much success. It's a messy job!
I put my reason for failure, because the modern say dot 5.1? (non silicon) is much milder than the old stuff. Meaning you can spill some on your tank and if you are quick you will save the paint. Whereas, the old stuff would ruin a tank quickly.
RegardZ.
lude
#5 PostAuthor: lude » Wed Feb 22, 2012 1:52 pm
Just found this while surfing, total strip down and clean Mikuni CV's
http://www.mtsac.edu/~cliff/storage/gs/Mikuni_BS-CV_Carburetor_Rebuild_Tutorial.pdf
should be useful
As mentioned in the article
Gunk CC3K Carburetor & Parts Cleaner with Drip Basket - 96 fl. oz.
[CC3K], £68.19
Delivery [United Kingdom]: £0.00
from
http://jtote.com/product_info.php/gunk-cc3k-carburetor-parts-cleaner-with-drip-basket-p-38
...lemon juice may be cheaper
#6 PostAuthor: paul doran » Wed Feb 22, 2012 2:29 pm
thats a good article plenty of detail
KwackerNut
#7 PostAuthor: KwackerNut » Wed Feb 22, 2012 9:32 pm
Hi
I bought an Ultrasound cleaner a few years ago, it was about £180.00 for a six litre tank (but you can get bigger - £££s).
I use it all the time, and the results are impressive. The 6 litre tank is not big enough to dunk a bank of 4 into, but i just turn them around.
A few tips;
You can get cleaning fluid to mix with the hot water, but be careful that it does not react with the ally, i had one carb go black. I use hot water and fairy liquid now.
Dismantling completely is best, but if not, try to remove all seals, as the best way to get all the crap out is by cooking as hot as possible. Mine goes up to 70 degrees, and blitz them for a few hours at least.
This kit does anything, caliper's, master cylinders, even the wife's jewellery. It's great watching all the crap just float away in the tank.
Jim
Far away across the field,
The tolling of the iron bell,
Calls the faithful to their knees
To hear the softly spoken magic spells.
zman
#8 PostAuthor: zman » Wed Feb 22, 2012 10:18 pm
Thanks for the help.
I have sonic cleaned them now.They are clean but there seams to be some slight corrosion that wont come off?
KwackerNut
#9 PostAuthor: KwackerNut » Wed Feb 29, 2012 8:09 pm
If the corrosion has tarnished the base metal, this discolouration will still be left behind, the ultrasound will only remove the oxidised crud.
I have read about soda and aqua blasting, and these may remove stubborn corrosion, but have not tried these techniques.
Jim
zman
#10 PostAuthor: zman » Wed Feb 29, 2012 9:58 pm
Thanks for help
Now sorted.Ali wheel cleaner did the job.Left them very clean and in there natural colour :) :)
will post pics on [Zmans cosmetic rebuild]when rebuild kit arrives
Users browsing this forum: Bing [Bot] and 71 guests
