Scary moment
SMR610
Scary moment
#1 PostAuthor: SMR610 » Fri Jun 15, 2007 7:44 pm
A couple of times now my bike has bogged down whilst trying to
make a quick getaway from a standstill, this afternoon was the
worst cos it did it on a busy roundabout with a car looming down
on me.
Bike is a GPZ1100 running CVs and seperate K&Ns, do you think
it`s this carb setup that is causing this problem or should I be
looking else where?
Any advice most welcomed or I`ll have to find a route to work
without roundabouts.
Allan
#2 PostAuthor: Pigford » Fri Jun 15, 2007 7:50 pm
Are they Dynojetted :?:
CV carbs are notoriously difficult to set up with K&N's (or any non standard filter). Either get a standard airbox or non CV carbs, Mikuni RS are best, for around ?200 on eBay :wink:
big green bus
#3 PostAuthor: big green bus » Fri Jun 15, 2007 8:24 pm
we need a bit more info on your bike cv type air box etc.
SMR610
#4 PostAuthor: SMR610 » Fri Jun 15, 2007 8:47 pm
Not sure what bike the carbs are off of but they are
standard issue Mikunis, was told they were
Dyno jetted haven`t checked though, if they are what
size would the jets be?
There is no airbox it`s got 4 K&N cone type filters.
#5 PostAuthor: Pigford » Sat Jun 16, 2007 3:31 pm
If Dynojetted, the needles are usually 'waisted' near the end, its also common for the hole in the casting that lets air into the rubber CV bit, to have been drilled out a bit. As for jet size, you need to know what the standards were :?
#6 PostAuthor: Rich » Sat Jun 16, 2007 4:59 pm
is this a new problem or has it always happened?
SMR610
#7 PostAuthor: SMR610 » Sat Jun 16, 2007 9:55 pm
I haven`t had this bjke long, it has done it before but I think
It was more noticable this time cos it happened in busy traffic.
Went looking for it today, if I use reasonable amounts of throttle
or have at least 3500rpm dialled in you`d never know there`s a
problem if the throttle is cracked open quick at lower revs then
it bogs down and gets spluttery release the throttle a bit and it
starts to pick up cleanly.
Users browsing this forum: Headspinning and 107 guests
