Brake indicator light in Tacho
Re fitted my clocks this weekend. The brake light never worked, blown bulb. Now that it has a new bulb it does not go out. tail light bulb is working. Any ideas why
warning light comes continuos on when rear brake light bulb blown its seeing an open circuit somewhere check the wiring diagram the make sure everything is connected
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Outage relay could be the problem Jon!! indicator light should flash if lamp has blown,the outage realy if you have one should be mounted near to the coils under the tank,it slips into a metal bracket on rh coil,if its duff they are a bit like Rockin horse crap...
Bruce Sexton
Should be on a plug Jon! unplug and see if lamp goes out,only way i know how to check op of these is by substution..Paul J
