carb sync
zman
carb sync
#1 PostAuthor: zman » Fri Mar 09, 2012 4:05 pm
Trying to sync my carbs after rebuilding them.\they are off the bike and useing the 3mm drill method.But i can only get three set the same.
Can someone discribe the process?
keep thoses wheels turning
#2 PostAuthor: kev edwards » Fri Mar 09, 2012 8:52 pm
Sounds as if you have gone to far in one direction and one of them has reached its stopping point, go in the opposite direction, when i first started playing with multi's i had a similar problem, i hope this makes sense, it does to me anyway.
DogsbolloxofZ1B
#3 PostAuthor: DogsbolloxofZ1B » Fri Mar 09, 2012 9:33 pm
You should be using 25thou wire, 3 mm drill :cry: The notch in the slide is narrow so not sure if a 3mm dia drill bit is too wide where it comes into contact with the notch. Give me a call 07515 367071 so I can talk you through the process.
Regards,
Mike
Users browsing this forum: zippy and 63 guests
