z1-z1a Early cam cover and swing arm spacer, please help
A1John
#1 PostAuthor: A1John » Fri Mar 16, 2012 10:20 am
z1-z1a Early cam cover and swing arm spacer, please help the spacer I need is the one that goes between the swing arm bushes, cheers.
GEZ635
#2 PostAuthor: GEZ635 » Sat Mar 17, 2012 8:50 am
The spacer you are taliking about is the tube in the swing arm inbetween the two bushes?Its just a steel tube so if you get stuck just go to your local stell stock holders and by a piece cut to length.
Gez
