Fork Tubes
redzee
Fork Tubes
#1 PostAuthor: redzee » Mon Mar 19, 2012 9:58 pm
Guys,
Does anyone know if Z1000J1 (1981) fork tubes are the same as/will fit my Z1000J3 (1983)?
Eight valve grunt.
#2 PostAuthor: z1bman » Mon Mar 19, 2012 10:31 pm
the j1/j2 are the same + the air valve is part of the fork top nut .the j3 has a hole in the tubes just above the bottom yoke + is covered + sealed by the air transfer tube which links the two tubes with air.
redzee
#3 PostAuthor: redzee » Tue Mar 20, 2012 7:17 pm
z1bman wrote:the j1/j2 are the same + the air valve is part of the fork top nut .the j3 has a hole in the tubes just above the bottom yoke + is covered + sealed by the air transfer tube which links the two tubes with air.
Cheers z1bman,
So if I took a pair of J1 tubes to work and blasted in new air holes in correct places (with a CNC EDM sinker) I would then have forks the same as the grotty J3 pair I have now.
Cheers for that.
Eight valve grunt.
#4 PostAuthor: z1bman » Tue Mar 20, 2012 8:21 pm
the fork top nuts are different i have no idea if they are the same thread size. but i would guess they are the same . fine thread i think?
