carb overflow pipes
tonyzx12r
carb overflow pipes
#1 PostAuthor: tonyzx12r » Mon Mar 19, 2012 11:35 pm
Hello. I want to replace the carb overflow pipes on my Z900A4 the part number is 92059-134. However this is just black fuel pipe, is there anywhere i could just buy pipe by the metre and cut it to size?
tonyzx12r
Z903
#2 PostAuthor: Z903 » Tue Mar 20, 2012 7:58 am
Can't see why you couldn't use something like 3/16" fuel line? I ended up using what they call "water" hose (not fuel resistant) not sure how long it'll last though. I think the right stuff has a Neoprene lining inside?
I have the actual lengths of each pipe written down here some place if you want them as well.
Think Z Power sell a set of these too?
pertonpc
#3 PostAuthor: pertonpc » Tue Mar 20, 2012 10:01 am
Z power do a set off the roll
You need about 2.5 metres to do all 4 carbs and each one has a little metal circlip to hold it onto the brass outlet.
1 + 2 need to be longer than 3+4 cos they all exit right side. I would suggest testing lengths with your old ones or a bit of string before making final cuts.
Cheers from Mark
