Z1000A1 Fork legs
JohnC
Z1000A1 Fork legs
#1 PostAuthor: JohnC » Sat Mar 24, 2012 2:34 pm
Must be in good condition. Will also take full front end if available.
John
kwakmac
#2 PostAuthor: kwakmac » Sat Mar 24, 2012 8:14 pm
I got a complete set from a z900 they are in good condition.one of the mudguard mount holes elongated boots need changed.otherwise ok.if any good to you 80 quid posted.i was useing them up till last year on my z1b but changed to standard.cheers james.ph no 07917611429.
JohnC
#3 PostAuthor: JohnC » Sun Mar 25, 2012 6:39 am
Hi James, not sure what you mean by mudguard mount holes elongated boots need changed?
John
kwakmac
#4 PostAuthor: kwakmac » Sun Mar 25, 2012 2:59 pm
One of the bolt holes for mudguard ovaled but threads ok.the dust seals are cracked and could do with being changed.
#5 PostAuthor: chrisNI » Sun Mar 25, 2012 8:38 pm
Mudguard hole is an easy helicoil if you're realy fussy, dust boots are easy to get from Zpower :wink:
