I fitted my new renthal chain and sprox on the ZRX today. The chain came with a 'soft' link but unlike any others I've seen. The pins appear to be solid and my chain riveting device doesn't seem to work on it. Normally these soft links have hollow pins with a softer end which is flared over to retain the link but this is different.
Any ideas? Is there some other means of securing the link? Any thought appreciated.
Drive chain soft link
- coldsummer
- Ginger Bear
- coldsummer
Ginger Bear wrote:Simon,
I have a proper 'mans' chain riveting device that'll sort that out for you. It will press a little square on to the end of your solid pins.
That sounds like the laddie Steve! I'll give you a bell in the next couple of days and come over and borrie it if that's ok. BTW I found your compression tester today, forgot it was even here
- Ginger Bear
Get it whacked between two lump hammers u gurl
Actually Simon I G clamped a lump of 50mm plate to mine and used an 8 oz ballpein hammer you don't get square bits on the pins but if your accurate you can get the same look as the factory tool
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- stephen parr
