Front brake discs.
bigalhudson
Front brake discs.
#1 PostAuthor: bigalhudson » Fri Mar 30, 2012 10:01 am
I've just had an advisory on my front brake discs on my Z1000 A1/2 (1978)
I can't see any for this model on Z Powers website. Any ideas which other models have these same discs for interchange.
Any pointers to a supplier for these?
The current discs are drilled and are measuring at around 4.56mm. The wear limit I understand is 4.5mm.
The few I have seen which may fit are £200 ish a side :shock:
Any ideas ?
london calling
#2 PostAuthor: london calling » Fri Mar 30, 2012 10:49 am
Pretty sure that all the 4 bolt discs from Z900/Z1000/Z1R/MK.2 should fit.
Later discs are factory drilled.
Maybe worth ringing Z-POWER as they don't list everything on the website.
TEL:01942 262864.
Jack
z2.john
#3 PostAuthor: z2.john » Fri Mar 30, 2012 10:58 am
Jack's right. Any 4-hole Z900/Z1000 should do.
Loads on ebay around the £30 mark
#4 PostAuthor: z1bman » Fri Mar 30, 2012 11:49 am
there is no minimum wear limit in the MOT testing manual. the only reason for failure on a brake disc is if it is warped or cracked. being under the manufactures wear limit is not a failure. if the brakes are working as they should i would leave them as they are
KWACKERZ1
#5 PostAuthor: KWACKERZ1 » Fri Mar 30, 2012 1:47 pm
The only reason an mot person would pick this up is by reading the stamping/casting on the disk, I have never had anyone check any of mine.
If they are badly scored then yes they would comments.
If you do decide to change them then any 4-bolt ones for a 1000/900 would be fine, but be careful as many ebayers sell z650 discs which are a smaller diameter as they don't know better.
Personally I would go EBC prolites if your buying new ones but as long as you have an mot I would not bother. Just take it soemwheer else next time. (Also look at the thickness of modern discs compared to these, I am sure youre's are actually fine.)
bigalhudson
#6 PostAuthor: bigalhudson » Fri Mar 30, 2012 3:33 pm
Thanks everyone. I would say they are fine to. No bad scoring at all and generally in good nick. Just a bit over zealous on the testing I think.
