Z650 bits
mikey
Z650 bits
#1 PostAuthor: mikey » Sat Mar 31, 2012 7:13 am
After a kick start shaft and the bits that go with it
a kick start and clutch cover as mine has a later clutch cover with no kick start hole.
And a wiring loom as mine has a home made one :roll:
Its a B1 if that helps thanks
And 1 rear foot rest mount as well
GUYZED
#2 PostAuthor: GUYZED » Sat Mar 31, 2012 10:47 pm
Mikey, i have a clutch cover and as i'm off to the VJMC jumble tomorrow i'll have look out for a kick start shaft and the bits and bobs that go with it.
#449
Z1000A2 Z650B1
mikey
#3 PostAuthor: mikey » Sat Mar 31, 2012 11:05 pm
Ok cheers guy and an actual kick start as well mate ill pm you
tomorrow evening regarding clutch casing
GUYZED
#4 PostAuthor: GUYZED » Sat Mar 31, 2012 11:18 pm
I'll give you a bell tomorrow at the jumble Mikey if i find anything...unless i want it for myself it is :wink: :wink:
#449
Z1000A2 Z650B1
mikey
#5 PostAuthor: mikey » Sun Apr 01, 2012 4:11 pm
Seems im sorted now apart cheers guy from the wiring loom and foot rest mount
GUYZED
#6 PostAuthor: GUYZED » Sun Apr 01, 2012 7:34 pm
Here you go Mikey...i know you only wanted the kick start shaft etc...but you can have half a engine instead :lol:
#449
Z1000A2 Z650B1
mikey
#7 PostAuthor: mikey » Mon Apr 02, 2012 8:11 am
Ok cheers guy
