Fuel Tap
carpy
Fuel Tap
#1 PostAuthor: carpy » Sun Apr 01, 2012 9:02 pm
Hi, I was wondering what would be the correct style of fuel tap on my bike should be. It's a bitsa I'm afraid, a KZ1000 A2 with 900 barrels on it, Z1B carbs and a Z1B tank (I think). The current fuel tap has 2 outlets at 90 degrees to each other which makes connecting the fuel pipe to the left hand carbs tricky, is this right.
Many thanks
000zeds
#2 PostAuthor: 000zeds » Sun Apr 01, 2012 9:21 pm
No it is not right , both outlets should be be together :!:
Zeds-R-Us
#3 PostAuthor: z1bman » Sun Apr 01, 2012 9:37 pm
sweptail
#4 PostAuthor: sweptail » Sun Apr 01, 2012 10:19 pm
My tap has two outlets at 90 degrees. Its ok to use but, as you say, can be tricky fitting the short fuel pipe.
carpy
#5 PostAuthor: carpy » Sun Apr 01, 2012 10:28 pm
Cheers, thanks for the replies.
CAT3
#6 PostAuthor: CAT3 » Tue Apr 03, 2012 10:35 am
Not sure about other 900 & 1000 models, but the Z900 was originally fitted with a fuel tap with the two outlets at 90 degrees to each other.
750steve
#7 PostAuthor: 750steve » Tue Apr 03, 2012 12:33 pm
CAT3 wrote:Not sure about other 900 & 1000 models, but the Z900 was originally fitted with a fuel tap with the two outlets at 90 degrees to each other.
Thats the way my 750 Twin tap is too.
Bruce Sexton
#8 PostAuthor: Bruce Sexton » Tue Apr 03, 2012 12:34 pm
My Z1A also had a fuel tap with the outlets at 90 degrees.
Bruce
scott
Junior Section leader
#9 PostAuthor: scott » Thu Apr 05, 2012 7:38 am
Hey Carpy.......the name ...........does it mean that you do a bit of carp fishing?
carpy
#10 PostAuthor: carpy » Sun Apr 08, 2012 10:58 pm
Ha, sorry, old school nickname I'm afraid :D
