Brass Cleaning 'Potion' ?
#1 PostAuthor: Ginger Bear » Wed Apr 04, 2012 8:14 pm
Hi all,
I currently have a set of carbs stripped to ultrasonically clean & rebuild, along with some new Keyster kits.
Question is, how can I clean up the brass parts (Drain bungs, float tang's etc) with minimal effort?
Should I just soak 'em in vinegar, cola or something stronger?
Thanks, in advance. :sou
Z1parR
#2 PostAuthor: Z1parR » Wed Apr 04, 2012 8:20 pm
I just put some vinegar in the water and turn the heat up , let the machine do the work then :wink:
0172 . Geoff Parr
Keefleaf
#3 PostAuthor: Keefleaf » Wed Apr 04, 2012 8:25 pm
Rumour says Lemon juice.
On large items lemon juice and scrub with salt mix?
PAULJAC47
#4 PostAuthor: PAULJAC47 » Wed Apr 04, 2012 8:45 pm
Hi Steve Brown sauce works well!!
steve bowdler
#5 PostAuthor: steve bowdler » Wed Apr 04, 2012 8:47 pm
Keefleaf wrote:Rumour says Lemon juice.
I think thats for Dover Sole :lol: :lol:
Z1parR
#6 PostAuthor: Z1parR » Wed Apr 04, 2012 8:50 pm
PAULJAC47 wrote:Hi Steve Brown sauce works well!!
On bacon butties :lol:
0172 . Geoff Parr
coldsummer
#7 PostAuthor: coldsummer » Wed Apr 04, 2012 8:59 pm
Mmmmm
Mark Tiller
#8 PostAuthor: Mark Tiller » Wed Apr 04, 2012 9:19 pm
Regular coke works on brass
07962421462
DaveZ1
#9 PostAuthor: DaveZ1 » Wed Apr 04, 2012 11:55 pm
At the risk of sounding controversial...... brasso or solvol autosol or is any form of elbow grease not allowed :lol: :lol:
#10 PostAuthor: kev edwards » Thu Apr 05, 2012 8:17 am
Dilute sulphuric acid/pickel will do the job, generally a 5% a bit stronger won't harm, battery acid diluted at 4 to 1 will do the job, or brick cleaner will even do the job, dip until clean then rinse with d/i water then dry off.
#11 PostAuthor: Ginger Bear » Thu Apr 05, 2012 2:30 pm
Kev,
I have some battery acid left over from buying a new battery. Should this be diluted 4 parts water to 1 acid, or the other way round?
#12 PostAuthor: Rich » Thu Apr 05, 2012 4:11 pm
Always add the acid to water - I think I got that the right way round :shock:
#13 PostAuthor: Pigford » Thu Apr 05, 2012 4:12 pm
Rich wrote:Always add the acid to water - I think I got that the right way round :shock:
...and more than likely 4 water - 1 aceeeed :wink:
#14 PostAuthor: kev edwards » Fri Apr 06, 2012 2:05 pm
Steve 4 parts water 1 part acid, add the acid to water it will generate a little heat but only a little as battery acid is only 28%, when finished it will be fine to send it down the sewer as there will be no noxious chemistry to contaminate the sewerage systems.
P.S you can also use it after to descale your kettle :)
Users browsing this forum: zippy and 63 guests
