Sprocket alignement
PAULJAC47
Sprocket alignement
#1 PostAuthor: PAULJAC47 » Fri Apr 06, 2012 7:08 pm
Guyz, anyone got a better idea on making sure the front and rear sprockets on my project line up exactly other than using a steel straight edge? Ta Paul J
#2 PostAuthor: Pigford » Fri Apr 06, 2012 7:26 pm
Best way is to put a chain on it and spin wheel - and see which side of the rear sprox it vears to :!:
#3 PostAuthor: z1bman » Fri Apr 06, 2012 7:33 pm
use a lazer level if you have one?
Re: Sprocket alignement
#4 PostAuthor: chrisNI » Fri Apr 06, 2012 8:48 pm
PAULJAC47 wrote:Guyz, anyone got a better idea on making sure the front and rear sprockets on my project line up exactly other than using a steel straight edge? Ta Paul J
What's wrong with a steel straight edge? :shock:
PAULJAC47
#5 PostAuthor: PAULJAC47 » Fri Apr 06, 2012 8:58 pm
Chris have had to use a spacer on the front,want to get it dead central to the chain..Paul
ade woollams
#6 PostAuthor: ade woollams » Sat Apr 07, 2012 6:27 am
steel straight edge is fine or a piece of string ,across the face of the rear sprocket and down to the front
