hi guys ,quick question,
fork oil level is quoted as 120mm in the manual, is that with the spring in or out ?
i,m presuming it is with it in and fully extended.
thanks knut
gpz1100 b1 fork oil level
what,s there to say except we,re all mad on here.
As above,... in the Kawasaki manual; "Same procedure for Z1000-K", measurement is taken with a tape measure from the top of the inner fork tube with the fork tubes compressed and in a vertical orientation. Main spring is removed for measurement.
Dimension is different for K model but 120mm is correct for B1.
- paul doran
