Rust in tank
Briz1
Rust in tank
#1 PostAuthor: Briz1 » Wed Apr 11, 2012 8:34 pm
I have a KZ 1000 which has very slight signs of pin pricks of rust in the tank.
I think it was stored for sometime in the States.
Is there a product I can use to seal it?
Blessed are the Zed Makers
tedsonthezed
#2 PostAuthor: tedsonthezed » Thu Apr 12, 2012 10:02 am
This is a regular subject on the forum. Is it just pinpricks of rust or really bad?
I have just cleaned my tank out with Frost's 'Marine Clean' and 'Prep & Ready' with superb results. What I liked about the Prep and Ready is that it coats the steel with zinc phosphate and provides a nice surface for a sealer such as their Por 15, although I didn't end up sealing mine as I didn't want to put sealer in unless it was really necessary.
There are plenty of other solutions if you 'search forum'.
You want how much?
Briz1
#3 PostAuthor: Briz1 » Thu Apr 12, 2012 5:57 pm
It's just very slight pinpricks of rust, not that bad at all but just want to sort it before it becomes a problem.
Could you let me know where you got it from?
Brian
#4 PostAuthor: ADRIAN H » Thu Apr 12, 2012 6:13 pm
tedsonthezed wrote: Frost's 'Marine Clean' and 'Prep & Ready' with their Por 15.
They are from Frost restoration,
http://www.frost.co.uk/automotive-rust- ... s.html?p=2
Briz1
#5 PostAuthor: Briz1 » Thu Apr 12, 2012 7:03 pm
Cheers :D
zman
#6 PostAuthor: zman » Thu Apr 12, 2012 9:26 pm
Ive just done this.someone suggested using rust remover from halfords.
you mix 1lt with a full fuel tank of Walter.
very easy and works great.left it for three days
keep thoses wheels turning
#7 PostAuthor: Ginger Bear » Fri Apr 13, 2012 7:10 pm
I've just done a tank with 'Biorust'. Works best if you leave it in for a few days. Next time I'll try the Halfords stuff, it'll probably be cheaper. :roll:
Briz1
#8 PostAuthor: Briz1 » Sat Apr 14, 2012 2:57 pm
That's a good result. Mine's no where near that rusty so I should be ok.
sneck
#9 PostAuthor: sneck » Sat Apr 14, 2012 8:45 pm
I used Brick/patio cleaner- acid in a tank ( from screwfix ), it cleaned up really when but its a suck it and see for how long to leave in depends how rusty it is .
http://www.screwfix.com/p/de-solv-it-pa ... 5ltr/12627
Sneck
Briz1
#10 PostAuthor: Briz1 » Sun Apr 15, 2012 9:22 am
Cheers guys
redzee
#11 PostAuthor: redzee » Mon Apr 16, 2012 8:42 pm
Eight valve grunt.
steve bowdler
#12 PostAuthor: steve bowdler » Tue Apr 17, 2012 7:07 am
Hi what do you guys use to blank off the fuel tap , I take it you do not leave the tap in situ as this may damage seals ?
#13 PostAuthor: Ginger Bear » Tue Apr 17, 2012 7:51 am
I left it on, & the cap. I would think twice though if I was using acid. :shock:
Keefleaf
#14 PostAuthor: Keefleaf » Tue Apr 17, 2012 9:14 am
steve bowdler wrote:Hi what do you guys use to blank off the fuel tap , I take it you do not leave the tap in situ as this may damage seals ?
I trimmed a wine cork,wedged it in.corkscrew to remove,Cheers.
steve bowdler
#15 PostAuthor: steve bowdler » Tue Apr 17, 2012 9:25 am
Mmm may have a few of those around :lol: :lol: :lol:
