Z1 tail unit
steve bowdler
Z1 tail unit
#1 PostAuthor: steve bowdler » Fri Apr 20, 2012 7:16 am
Hi thinking of changing the tail unit of my Z1000 for an early replica Z1 unit
what are the extra holes on the earlier units , is it for the lens or wires the lower holes obviously attaching to frame bracket
Keefleaf
#2 PostAuthor: Keefleaf » Fri Apr 20, 2012 8:05 am
Think the holes are for rubber dampers for tool tray.
It will fit no problem.maybe need earlier tool tray/not sure.
steve bowdler
#3 PostAuthor: steve bowdler » Fri Apr 20, 2012 8:12 am
OK thanks have to re-check my tail unit again, what with my tail tidy sure that tray would get in the way of the light unit ?
#4 PostAuthor: chrisu » Fri Apr 20, 2012 9:00 am
tool trays are different - the earlier Z1 has a bigger taper on it so the later ones are too wide at the back (if that makes sense)
neilbarrett
#5 PostAuthor: neilbarrett » Sun Apr 22, 2012 6:37 pm
differnt curve so the seat wont fit as good looking at it from the rear,so youmight want to change that to
Mark Tiller
#6 PostAuthor: Mark Tiller » Sun Apr 22, 2012 7:52 pm
This is my A1 with Z1 tailpiece and tailtidy fitted showing the contour of the seat against the tail.
the rear tray from the A1 does not fit inside as previously stated
Another view when grabrail is on
07962421462
Users browsing this forum: Bing [Bot] and 50 guests
