Timing Question
Timing Question
Trying to set my points with a circuit tester to do static timing, in the book it says to conect the meter to the spring and earth, using audible tone to measure when the points just open at top dead mark, my prob is the meter buzzes all the time, that is when points are open or closed, it only works when I disconnect the lead to the coil, is it suppose to do that or do I have a short, the motor starts and runs mostly ok? its on a 250 twin by the way!
Hi David are you doing this with the battery connected? if so disconnect it and try again, sounds like meter is picking up voltage when you have it on the ohms scale..Cheers Paul J
Users browsing this forum: Bing [Bot] and 49 guests
