Fork Length
mole
Fork Length
#1 PostAuthor: mole » Sat Jun 30, 2007 3:20 pm
Can anyone tell me the standard length of a Z900 ('73 ish) fork from wheel centre to top of stanchion, please? I've got a chop project going and, after much head-scratching, I've worked out that the front end is off a Z900 or Z1 (the rest of it is CB750 SOHC....). The forks look lengthened but I can't be sure. They are 895mm long and 35mm dia.
Thanks,
Brian
Garn 1
#2 PostAuthor: Garn 1 » Sat Jun 30, 2007 9:47 pm
The distance from the wheel centre to the top of the fork tube is approx 770 cm when on centre stand. A standard fork tube length for a Z1/ Z900 when measured dissassembled from fork leg is 615cm.
RegardZ.
Teddy
#3 PostAuthor: Teddy » Mon Jan 28, 2008 3:07 pm
Garn 1 wrote:The distance from the wheel centre to the top of the fork tube is approx 770 cm when on centre stand. A standard fork tube length for a Z1/ Z900 when measured dissassembled from fork leg is 615cm.
RegardZ.
Can anybody confirm these measurements? Are they the same for z1000 A1?
Thankz..... :D
-77 z1000 turbo
#4 PostAuthor: Pigford » Mon Jan 28, 2008 6:56 pm
Mole, Z1000A1 forks, 35mm dia & 770mm long :wink:
Teddy
#5 PostAuthor: Teddy » Tue Jan 29, 2008 8:51 am
Thanks Pigford. :D
-77 z1000 turbo
