totally thick on electrics!
nealblath
#1 PostAuthor: nealblath » Sat Apr 28, 2012 1:57 pm
just sorting out the wiring on my 74 Z1A but like a t**t I didn't label everything 8 years ago!
pretty much done but there is a little box slung under the battery compartment, regualtor or rectifier?, which has a cable with 4 wires and a green plug on which is obvious where it plugs in, but it also has a single black wire which I am not sure where it goes........help please!
MCZ900
#2 PostAuthor: MCZ900 » Sat Apr 28, 2012 1:58 pm
I have the same wire wondering the same myself
1973 Z1 and 1976 Z900
z2.john
#3 PostAuthor: z2.john » Sat Apr 28, 2012 2:42 pm
Black wire is the earth and needs to bolt direct to the engine (or frame)
nealblath
#4 PostAuthor: nealblath » Sat Apr 28, 2012 3:00 pm
thanks John
Bill Newman
#5 PostAuthor: Bill Newman » Sat Apr 28, 2012 8:23 pm
And on mine that black wire is fitted to the bolt that hold the seat lock ...
nealblath
#6 PostAuthor: nealblath » Sat Apr 28, 2012 8:26 pm
thanks Bill
CAT3
#7 PostAuthor: CAT3 » Sat Apr 28, 2012 9:26 pm
If it's long enough it would be best connected direct to the battery -ve terminal. I'm sure later modified versions of the regulator had a separate black wire which was intended to connect direct to the battery instead of it being connected via the green plug to an earth.
