Z900A4 Brake splitter spacers
Bill Newman
#1 PostAuthor: Bill Newman » Tue May 01, 2012 8:49 pm
The brake splitter on my A4 is mounted to the lower yoke by a pair of 45mm long bolts that also hold the cable eyes. There is a spacer on each bolt that holds the splitter away from the yoke. One of mine is missing and I cannot find a part number for it in the parts book. The spacer is 10mm O/D and 12mm long
Is this a bodge ( the bike has had a front end prang at some point and not been well repaired) or should they be there?
If so, has anybody got one I can buy, beg etc,etc
Or do I mount the splitter so that it abuts the face of the lower yoke and use shorter bolts? :??
#2 PostAuthor: z1bman » Tue May 01, 2012 9:23 pm
1 43015-032 CYLINDER ASSY,MASTER Not Available
2 43073-001 REPAIR SET-MASTER CYL $42.57
3 43025-001 STOPPER-BOOTS Not Available
4 43024-001 BOOTS Not Available
5 481J1800 CIRCLIP,18MM $2.97
6 43022-001 STOPPER-PISTON Not Available
7 43072-001 PISTON ASSY Not Available
8 43019-001 CUP-PRIMARY Not Available
9 43018-001 SPRING ASSY-RETURN Not Available
10 43017-001 VALVE ASSY-CHECK Not Available
11 43029-003 LEVER,FRONT BRAKE $41.75
12 43033-004 BOLT Not Available
13 312AA0600 NUT-HEX $2.97
14 43031-001 WASHER-LOCK,8MM Not Available
15 317AA0800 NUT-HEX-SMALL,8MM $2.97
16 43030-003 BOLT,LEVER ADJUSTING Not Available
17 43026-1054 CAP-BRAKE Not Available
18 43027-001 PLATE-MASTER CYLINDER $5.04
19 43028-001 DIAPHRAGM $16.83
20 112N0625 BOLT-UPSET $2.97
21 411AA0600 WASHER-PLAIN,6.5X13X1 $2.97
22 43034-001 HOLDER-MASTER CYL Not Available
23 49091-0001 WASHER-SEAL,10.1X14.5X1.5 $2.97
24 92153-0627 BOLT,OIL,L=23 $2.97
25 49006-1041 BOOT,DUST $5.23
26 43059-022 HOSE,FRONT BRAKE Not Available
27 43065-001 SWITCH-FRONT BRAKE Not Available
28 43061-002 JOINT,THREE WAY Not Available
29 110N0636 BOLT HEX HEAD 6X36 Not Available
30 110N0645 BOLT,HEX HEAD,6X45 Not Available
31 461DA0600 WASHER-SPRING,6MM $2.97
32 411AA0600 WASHER-PLAIN,6.5X13X1 $2.97
33 43059-011 HOSE,FRONT BRAKE Not Available
34 43060-021 PIPE,BRIDGE Not Available
35 43063-001 BRACKET-BRAKE HOSE Not Available
36 43064-001 GROMMET-HOSE BRACKET Not Available
37 92027-162 COLLAR,6.8X10X12 $3.53
38 11012-1037 CAP,FRONT BRK SWITCH Not Available
#3 PostAuthor: z1bman » Tue May 01, 2012 9:37 pm
bill. the two collars are only fitted to the single disc brake splitter. if you have the twin disc splitter you do not need the collars. although i cannot see what purpose they serve
tlc
#4 PostAuthor: tlc » Wed May 02, 2012 6:15 am
Are they not for the headlamp support bracket ?
paulstrees
#5 PostAuthor: paulstrees » Wed May 02, 2012 6:28 am
No headlamp support bracket on an A4 due to the indicator warning buzzer
Bill Newman
#6 PostAuthor: Bill Newman » Wed May 02, 2012 8:16 am
Thanks everybody,
It did not occur to me that the single disc set up would be different to the double disc - and it was the double disc page that I was open when rebuilding the front end. :roll:
The thread has achieved two things - first it confirms that the A4 does have these spacers and second and really pleasingly I have had a pm and one is on its way to me....
Another example of the spirit and comradery in this club.
Users browsing this forum: Bing [Bot] and 42 guests
