Z900 A4 Headlamp ears
Bill Newman
#1 PostAuthor: Bill Newman » Wed May 02, 2012 8:16 pm
Had a bad time today whilst rebuilding the front end of my bike. I fitted a replacement headlight ear (for one that came off the bike - because it was bent), only to find that the headlight was angled to the nearside - instead of aligning straight ahead. After thinking the fork legs were twisted I took everything apart and rebuilt it again - with the same result. I checked everything with a laser and found all was straight and square on the forks.
Then I discovered that the ears were different...the original has a dimension of 123mm from the back of the tube to the front edge of the arm whilst the replacement has a dimension of 132mm
Which one is right? I now have to try and find a good one of the right length...
Steve Cooke
#2 PostAuthor: Steve Cooke » Wed May 02, 2012 8:43 pm
Bill I measured mine at 120mm approx. and they are originals so I would say your 123mm is the correct one.
Bill Newman
#3 PostAuthor: Bill Newman » Thu May 03, 2012 7:36 am
Thanks Steven - now off to have alook round pmc/Zpower etc etc
