bolts needed
bolts needed
the gremlin theives have been at it again,just started to rebuild my project engine,and found out that there are quite a lot of bolts missing,honestly you strip a complete engine down,put everything away safe,then when you need to rebuild it,there gone awol.the bolts i need are seven of the bolts that hold the crank down.i have the four that go on the centre bearings,but rest are gone.if anyone can help me out ,i would be most greatfull,thanks,brent.
crankcase bolts
brent ! i will send these bolts down when i post your side panels mate.
