hi guys,i,m new here and looking for the standard air mixture and other settings for a standard kz900,as i think it,s getting too much petrol on #1 .
thers plenty of spark but #1 exhaust is not getting anyway as hot as the others.
there seemed a lot petrol in mix that it spat out when i removed the plug while checking the spark,
any help much appreciated
regards knut.
kz900 carb settings
kz900 carb settings
what,s there to say except we,re all mad on here.
Pigford wrote:Sounds more like a dodgy plug? If its an NGK, they seem to be iffy?
Swap 1 & 4, see if problem moves? If not, swap leads, they are both the same coil, so thats OK!
If its still No 1, carb could be flooding? Air screw out 1 1/4 - 1 1/2 turns.
thanks pigford ,
i,ll try swapping them around 2moro,leave ye know whats happens ,cheers
- z1bnackerkwacker
Only ?33 for 4 kits to rebuild from Z1 enterprises @ (todays rate), if you do it yourself, piece of piss, that's where I got mine, runs great now.......
Air screws: I have a book that says as much as 2 and a half turns out as 1-1 and a half is too rich, Something you will have to try for yourself, no 2 air mixture screw seats are gonna be identical.....
p.s If you've got genuine Kz carbs (3 screw) the balance screws will be under carb tops (If you don't already know) , not as z1...
Last edited by z1bnackerkwacker on Tue Jul 03, 2007 7:07 pm, edited 2 times in total.
Just to elaborate:
Carbs with screw under carb throat, near cylinder, is a FUEL enrichening adjuster. This one will let extra fuel in the more it is opened (anti-clockwise = richer)
Carbs with AIR screw, on inlet side, lets more air in, weakening mixture (anti-clockwise = weaker).
Therefore, if its air jet screw, be aware that further out is WEAKER.
z1bnackerkwacker Posted: Tue Jul 03, 2007 2:50 pm Post subject:
Air screws: I have a book that says as much as 2 and a half turns out as 1-1 and a half is too lean, Something you will have to try for yourself, no 2 idle seats are gonna be identical.....
- z1bnackerkwacker
