Exhaust clamp torque
corpy
#1 PostAuthor: corpy » Mon May 07, 2012 11:26 pm
Thanks to help and advice from people on this forum my Z1100 1981 A2 (1?)-engined trike is now off-sorned and MOT'd. Compression pressures are only 112-115 hot with an open throttle, but this is after glaze busting and re-ringing so they will improve, I hope.
I can't see a torque figure in the Kaw or Clymer manuals for the 8 exhaust pipe-to-head clamp nuts.
The four new soft gaskets must be squashed to gas-tight but the aly head is 31 years old, so I would rather use a recommended torque figure if there is one.
Brass nuts are or were commonly used in this position but I haven't noticed them on bikes (unless they have been chromed). Perhaps brass ones wouldn't happily take the required torque?
More advice please.
Thanks.
#2 PostAuthor: chrisNI » Tue May 08, 2012 8:07 am
If there's no specific figure quoted you could just use the figure indicated for the stud size should be in the Kaw manual somewhere.
corpy
#3 PostAuthor: corpy » Tue May 08, 2012 8:44 am
Yes I could and I will if nothing more comes along.
I thought that I might as well make use of the wide Kawasaki knowledge available here.
For instance I am hoping to be told whether, after all these years of heating and cooling, the alloy of the head becomes softer or less tolerant of excess tension.
Thanks.
#4 PostAuthor: Ginger Bear » Tue May 08, 2012 9:02 am
Just 'nip' them up by hand, if the exhaust still blows, 'nip' 'em up a bit more.
