Points cover paint
steve bowdler
Points cover paint
#1 PostAuthor: steve bowdler » Fri May 11, 2012 7:28 am
Hi what do you guys use for the black on the points cover enamel , or just a gloss black ? Ta
tlc
#2 PostAuthor: tlc » Fri May 11, 2012 7:41 am
Gloss enamel Steve.
Do a nice thin brush coat getting into the corners and allow to dry for a short while. Put brake cleaner or lighter fluid on an industrial type paper towel. Stretch it over a flat wooden baton and wipe over changing the towel after each pass.
Repeat as necessary. Two coats should be enough.
steve bowdler
#3 PostAuthor: steve bowdler » Fri May 11, 2012 7:51 am
Thanks mate remembered the trick just not the type of paint Thanks again for your help
:D
