Z1A throttle slide heights
nealblath
#1 PostAuthor: nealblath » Fri May 11, 2012 8:04 am
I noticed from previous posts that it recommends setting slide heights at 0.7mm.........what does this mean and how do you do it?
I am planning balance carbs when engine is running so does this mean I don't have to bother setting slide heights now?
thanks Neal
#2 PostAuthor: chrisu » Fri May 11, 2012 9:33 am
yes you should do this - it gets them roughly in the right area to balance.
it also stops them being too high and hence revving the nuts off it when you start the bike.
:shock:
nealblath
#3 PostAuthor: nealblath » Fri May 11, 2012 9:58 am
chrisu wrote:yes you should do this - it gets them roughly in the right area to balance.
:shock:
thanks Chris
how do you do it?
where does the 0.7mm refer to?
#4 PostAuthor: chrisu » Fri May 11, 2012 10:18 am
i've sent you a link to the manual - you can then download it.
nealblath
#5 PostAuthor: nealblath » Fri May 11, 2012 12:14 pm
thanks Chris
nealblath
#6 PostAuthor: nealblath » Fri May 11, 2012 1:53 pm
figured out how to do it now
nealblath
#7 PostAuthor: nealblath » Mon May 14, 2012 9:12 pm
When setting the 0.7mm gap, do you measure from the top of the little notch at the front of the slide to the bottom of the bore, or from the bottom of the slide, where the notch is, to the bottom of the bore?
