too many early Z1 heads???
malmojoe
#1 PostAuthor: malmojoe » Mon May 14, 2012 8:35 am
I have been looking for an early Z1 head for my bike and know that there is no O ring groove and that the bosses where the vacuum take offs are still there in the casting - and not there in the Z1000 head - even theough the O ring has dissappeared.
Dave Marsdens book says that the O ring was introduced about 14000 or something, so that should make the earlier heads pretty scarce, but there seems to be a lot of later heads (78 and so on) in USA which also have no O ring and the bosses still in the casting. What are they from and are they really tha same as the early Z1 heads or not?
clarity much papreciated before I waste more money :??
Garn 1
#2 PostAuthor: Garn 1 » Mon May 14, 2012 9:01 am
MalmoJoe, I think you may be confusing the groove in the head with the groove in the barrels. There is no 0-ring groove in the head. It's an easy mistake. Have a look at Zed1015's photo of the barrels (your posting... "Can you identify this piston?"
I'm not sure if they still had the o-ring groove in the barrels of the Z1000-A2, however, the Z1000-A1 had the groove in the barrels. all Z1ooo's had no boss for vacuum nipples.
RegardZ.
malmojoe
#3 PostAuthor: malmojoe » Mon May 14, 2012 9:08 am
Cheers Garn, I was thinking that it would be an engineering nightmare to match up those grooves :lol: ..
So, all the 900 heads are the same as mine and anyone will do ???
Keefleaf
#4 PostAuthor: Keefleaf » Mon May 14, 2012 10:08 am
NO ! :D
malmojoe
#5 PostAuthor: malmojoe » Mon May 14, 2012 10:10 am
eh?? not the same?
Keefleaf
#6 PostAuthor: Keefleaf » Mon May 14, 2012 10:13 am
There was a post on early heads way back,prob' lost in meltdown?
I've got a couple of earlyish heads,subtle changes.
I will Email you images,maybe you could post them up,( I can't).
malmojoe
#7 PostAuthor: malmojoe » Mon May 14, 2012 10:16 am
cheers Keith.
hutch
cylinder heads
#8 PostAuthor: hutch » Mon May 14, 2012 10:05 pm
some z1000s and z1rs have the boss castings for the vacuum take offs , i also have some z900s ,some with the casting ,some without .i have also seen a head without the boss but with the narrow outer fins .you dont honestly think they just had the one mould for all the heads cast .
malmojoe
#9 PostAuthor: malmojoe » Tue May 15, 2012 8:05 am
bloody hell Hutch, I just thought I was getting a handle on it. :lol:
