Wanted a twistgrip throttle tube for a z1b z900
Padders
#1 PostAuthor: Padders » Sat May 19, 2012 7:28 pm
Hi I am looking to buy a twist grip for my Z1B as mine has a fast action throttle fitted. Not sure if the Z900 Z1000 one is the same if some one could let me know.
#2 PostAuthor: Pigford » Sat May 19, 2012 7:41 pm
I'll buy the quick-action throttle if you're selling :?:
malc87
#3 PostAuthor: malc87 » Sat May 19, 2012 7:44 pm
Padders
#4 PostAuthor: Padders » Sat May 19, 2012 7:55 pm
As soon as I sort a standard replacement its yours Mark
#5 PostAuthor: ADRIAN H » Sat May 19, 2012 7:56 pm
#6 PostAuthor: z1bman » Sat May 19, 2012 8:33 pm
this would probably do the job if you changed the rubber grip to the z1a type but not sure the holes for the cable nipples are the same distance apart + you might have problems fitting the cables. but i am sure someone at z power would know
prowlerz1
#7 PostAuthor: prowlerz1 » Sat May 19, 2012 10:35 pm
ive got one for you ian
73 z1 green
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
Padders
#8 PostAuthor: Padders » Sun May 20, 2012 5:23 am
Cheers Martin will give you a call
